Hi EC,
I'm not sure. Loading a Tool doesn't mean you necessarily want the Tool Length Active. Also the tool slot T might not equal the Tool number H. Yo can probably add that functionality into an M6 program.
Message: 8246 |
Date: 9/3/2013 |
Subject: Re: KMotionCNC Tool Change Option question |
I see what you are saying. The Tx command will pull out the tool in position x, but that is not necessarily tool number x in that slot. I guess the best way to handle it is I will add a check box selecting whether you want the offsets applied when a tool is manually selected from the drop down.
I also add a tool tip that displays the Comment listed in your tool table for the currently selected tool. Eric
--- In DynoMotion@yahoogroups.com, <dynomotion@yahoogroups.com> wrote:
Hi EC,
From: "eric@..." <eric@...> To: DynoMotion@yahoogroups.com Sent: Tuesday, September 3, 2013 6:46 AM Subject: [DynoMotion] RE: KMotionCNC Tool Change Option question
Oops, I meant G43 Hx
--- In dynomotion@yahoogroups.com, <eric@...> wrote:
Tom, In modifying the application, I notice that when you select a different tool from the drop down, it constructs a TxMx command. Shouldn't it also use H43 Hx to invoke any defined offsets as well?
